625rwhp 2 Valve
625rwhp 2 Valve
What is it capable of with practice?
Specs...
DSS Level 10 Long Block Assembly
P-51 Intake
Patriot Stg 2 Ported Heads
Stg 2 Comp Cams
D1SC with dual BOVs
Anderson Power Pipe and filter
90mm MAF
82LB Low impendence injectors with injector drivers
Aeromotive Fuel sump with AN fuel lines
TKO 600 trans
Tri-Ax STS
Aluminum DS
Clutch upgraded
Granantelli K-member and A-arms
Front coil overs
Rear adjustable shocks
LCA/UCAs
Weld in subframe connector
6-point roll bar
Torque boxes
17x8 front, 17x10.5 rear Nitto DRs
625 RWHP at 20lbs boost, 692 RWHP on a 35 shot.
So what ca it do or not do? Its a friend of mine. He built the car 7 years ago and its mostly sat in his garage (yea, I don't like it either). The car sounds like a damn jet. Any ideas?
Specs...
P-51 Intake
Stg 2 Comp Cams
D1SC with dual BOVs
90mm MAF
TKO 600 trans
Tri-Ax STS
Aluminum DS
Clutch upgraded
Front coil overs
LCA/UCAs
6-point roll bar
Torque boxes
Specs...
P-51 Intake
Stg 2 Comp Cams
D1SC with dual BOVs
90mm MAF
TKO 600 trans
Tri-Ax STS
Aluminum DS
Clutch upgraded
Front coil overs
LCA/UCAs
6-point roll bar
Torque boxes
Specs...
P-51 Intake
Stg 2 Comp Cams
D1SC with dual BOVs
90mm MAF
TKO 600 trans
Tri-Ax STS
Aluminum DS
Clutch upgraded
Front coil overs
LCA/UCAs
6-point roll bar
Torque boxes
Ive seen plenty of 600+ rwhp manual cars go mid 11s lol
TfcCDR
09-14-2015 12:08 PM
