Tuner Central Have a question about which hand tuner is best for your Mustang? Talk about it here!
05 GT, Eforce supercharger tuning questions
Old 06-30-2019, 10:51 PM
Justin302
Justin302's Avatar
Default 05 GT, Eforce supercharger tuning questions
I purchased an 05 Mustang that was already built and tuned by the last owner. The last owner passed away before he fully completed his/my supercharged mustang. The car runs awesome and I have pulled away from a new z06 vette, the current tune is pretty good.
There are some things however that need to be adjusted that I just don't know how to do. The warm up cycle is super rich. I am an extreme newb at this and am eager to learn so any help will be appreciated! I will also share my existing tune to help others out! I just wish I knew all the mods on the car. It has comp cams phaser limiters, so it might be cammed. It has a 2.75" pulley on the Eforce supercharger, 60lb injectors, longtubes, 6 speed manual, some custom read all pids on the stock odometer readout, lots of work done. Thanks
Justin302 is offline
Old 07-01-2019, 09:15 AM
proeagles
proeagles's Avatar
That charger came with a factory tune designed for a stock engine which is perfectly fine to begin with. When you modify the engine further, the tune no longer works as you are finding out. Your only solution is to find a professional engine tuner with a dyno and have them re-calibrate your tune.
proeagles is offline
Old 07-01-2019, 10:03 AM
Justin302
Justin302's Avatar
I understand that, and the car runs great just needs the warm up cycle to be leaned out. I just thought this was a forum where people help people with tunes.
Old 07-01-2019, 10:08 AM
Justin302
Justin302's Avatar
Forgot to mention I hot hp tuners hoping I could figure it out but need to find information to help me understand how to lean the warm up cycle.
Old 07-02-2019, 04:56 AM
Analyzer52
Analyzer52's Avatar
I have the the same blower and it was custom dyno tuned. My tuner left mine a little rich also but said it was on purpose as it is better to be a little rich than to run lean. Like others are telling you the right way to fix it is have someone do it. To risky to mess with yourself they will also see if there are other areas for improvement. This is best especially since you don't know the history of the car. Mine makes 500 horsepower to the wheels, you want it done right.
Analyzer52 is offline
Justin302
07-01-2019 04:26 PM
sonicv3gt
Tuner Central
02-25-2017 02:05 PM
pdub42
03-02-2010 07:30 PM
prollynotjeff
09-29-2009 08:33 PM
Speedeamon
12-23-2005 03:47 PM
Quick Reply: 05 GT, Eforce supercharger tuning questions
