HOW CAN I TURN YOU THE BOOST ON MY 1988 TURBO COUPE?
i have a 1988 thunderbird turbo coupe im making about 8 pounds of boost now the guage goes to 18 i want to make about 12. how do i turn the boost up also is there anything else you recomend doing after turning it up ?
RE: HOW CAN I TURN YOU THE BOOST ON MY 1988 TURBO COUPE?
ORIGINAL: kl92gt
stop listening to them all, except Tbird232ci, he is the one you bow to
www.boostvalve.com
i bet you could probably run 16-17psi safely in premium mode (on 93)
i run 19 in mine with an upgraded fuel pump and intercooler
www.boostvalve.com
just be EXTRA careful, only turn it a half turn at a time NO MATTER what, from experience
i thought i turned mine back to where it was (after turning it down) i spiked 25psi ONCE and it blew my headgasket wide open
ORIGINAL: kl92gt
its a 5spd. thanks mr. merk ill end up getting a boost valve
Reason i ask about a 5-speed or auto, is that from the factory, the boost is controlled by the computer and a selenoid, and the 5-speed cars got more boost than the automatics. Automatics usually got 10psi, while the 5-speed cars got 15psi.
