Wheel spacers
Has anyone lowerer their car and added wheel spacers on the rear? if so what size and what brand. please post pics. What are the pro's thoughts on the wheel spacers? |
RE: Wheel spacers
i want to know too...i have 1in spacers on the rear right now and may be lowering soon...was wondering if there would be any problems as far as stress on the hubs and wheel studs
RE: Wheel spacers
Someone help US please! :)
RE: Wheel spacers
i've had spacers on my ruck for 6 years with no problem. you should be good. i also have the ones with the integrated studs. don't get disc type as they can cause stud failure
RE: Wheel spacers
if you lower it a lot and have the wheels in the rear come out too much you will shred your tires on bumps. I have a 1.5" drop and put 1" spacers to make a 10" wide rim in the rear.....drove for 2 days and shredded the lip of my tires.....took them off. Just be careful
RE: Wheel spacers
ORIGINAL: Autobadges.com if you lower it a lot and have the wheels in the rear come out too much you will shred your tires on bumps. I have a 1.5" drop and put 1" spacers to make a 10" wide rim in the rear.....drove for 2 days and shredded the lip of my tires.....took them off. Just be careful |
RE: Wheel spacers
the inner lip of the fender hits the outside lip of the tire
RE: Wheel spacers
gotcha. do you think it would rub w/ a 9in wheel?
RE: Wheel spacers
no
RE: Wheel spacers
cool. this is way off topic, but i was wonderin if you knew of anything that i can put on my 232 emblems to make the webbing gloss black....the way it looks when they are wet.
