Oil Dipstick replacement?
My oil dipstick tube has been broken on my motor. There is still part of the tube in the motor. Where does the tube insert into the motor? And where can I find a replacement tube. I have a 94 mustang convertible v6 3.8
RE: Oil Dipstick replacement?
holy crap that has go to suck bad.
Maybe you could use one of those little pen looking things that extract and have the magnet on the end to get it out?
But you could prolly get another dipstick from a junk yard.
ORIGINAL: 94droptop
where do i find the location where the tube insert into the engine?
Uhh, do this with the engine cool.
If the other people's ideas are not working for you, and if you ahve stick left in the block, you might try this: loosen the nut that's holding the tube down (on the exh mani, its the only thing holding the tubedown in place). Slide the tube up enough to clear the block and so you can get your fingers on the remaining stick, then work it all out together.
me= '98 vert
zanemoseley
09-06-2015 12:58 PM
