acceleration problem
#21
RE: acceleration problem
ORIGINAL: VCS_SSSTANG
And thats the other half of your problem.
ORIGINAL: 00StangV6
my cel stays on, took the converters off and didnt put two of the 4 sensors back in. i hope this is the problem and i promise you, i will never use any type of bosch products
#22
the two closest to the motor were put back in but the back two wasnt. i took off the converters which the back two were screwed in and replaced it with strait pipe.from wat i understand it wont hurt anything jus makes the cel stay on but i could be wrong. theyve been out for atleast a yr. dont see why it would all a sudden start afecting the car now
#23
ORIGINAL: 00StangV6
#24
ORIGINAL: 00StangV6
This could give you a clue as to what is going on. I'd suggest, go to Autozone & pull the codes, then post them back here. We might be able to help you better, instead of you spending money on wild guessing ?
#29
ORIGINAL: 00StangV6
can i do that odometer trick that shows ur rpms and speed and stufff digital. that shows u coedes right
