I was going to install myself, but even a shop will do it for little to nothing.
man shops are expensice. The cheapest i found was $300. And that was just for springs. I'm going to ask friend of mine to see if he can install them for me. If he said yes then i def let u know..
Wtf are you talking about? This is the simplest DIY ever. Jack up the car, unbolt the top nut/bolt from strut tower, and the bottom from the controller arms, push down on the control, and the spring should fall right out, then unbolt the shock from the controller arm and then repeat the process backwards which should be easier since the springs are shorter, dont get an alignment until after about a week, more or less same for the rears.
WTf is wrong with you.. its easy to say.. but if you dont have the tools you cant do anything.
