is this a Deal or wat
Old 09-29-2009, 02:58 PM
ramoyer1
ramoyer1's Avatar
Default is this a Deal or wat
OK my trans (aode) transmission is dead! I found a 2000 mustang for 700 bucks and it has a 5 speed. If i buy this car i will want to put that 5 speed in my 2001 mustang. What else would i need other then flywheel for a 2001 motor.
ramoyer1 is offline
Old 09-29-2009, 03:07 PM
vagabond
vagabond's Avatar
How many miles does the 5 speed tranny have on it? You may not want to put the work into it if it's already got an assload of miles on it..
vagabond is offline
Old 09-29-2009, 03:10 PM
brent4
brent4's Avatar
If your getting the whole car for 700 then jump on it. As for the t5 swap your going to need the flywheel(as you stated), t5(guess you knew that), driveshaft, clutch pedal assembly, and iirc you will need some trans wiring. But if youve got a donor car you will be just fine.
brent4 is offline
Old 09-29-2009, 03:11 PM
ramoyer1
ramoyer1's Avatar
thats ture it has around 120k on it. the car hit a deer and totaled it. motor is good 2!
ramoyer1 is offline
2000Stanglover
2000Stanglover's Avatar
Is your car an auto right now???
2000Stanglover is offline
Old 09-29-2009, 03:12 PM
brent4
brent4's Avatar
What do you plan to do with the motor?
brent4 is offline
Old 09-29-2009, 03:13 PM
2000Stanglover
+1 one all he said. I was going to do it but i was low on cash and i got a trans for 400 bucks with only 13k on it.
Old 09-29-2009, 03:15 PM
ramoyer1
ramoyer1's Avatar
yes my car is a auto....it suks so bad it held together for a good bit untill i had a 2500rpm stall droped in and started sparying a 75 shot off the line in first gear.Plus i love a 5speed anyways!! prolly sell the motor
ramoyer1 is offline
ramoyer1
ramoyer1's Avatar
yes 700 for the WHOLE car with everything still in it.
ramoyer1 is offline
Old 09-29-2009, 03:18 PM
brent4
brent4's Avatar
If your willing to sell the motor or part it out hit me with a pm i could use a set of heads and intakes.
brent4 is offline
Quick Reply: is this a Deal or wat
