Thermostat Questions
ok so I've read that the stock thermostat is a 195 degree unit, and I've also noticed that my car runs stronger when it's cooler. so my questions are:
1 will it cause damage to install a 160 unit
2 will that affect AFR
3 will it consequently affect MPGs
4 or would it just lower operating temps
I've also read that at lower operating temps cause the car to run leaner which seems to be helpful to my car (no pings, just better power)
also if i do install a lower temp thermostat what style rad fan thermostat do i need a push in or screw in and what temp should i set it at.
check out this link dude, hope it answers some of your questions
http://www.miracerros.com/mustang/thermo.htm
i dont need to know how to install the engines thermostat, known how to do that. im talking about the thermostat on the radiator that tells the fan its time to cut on. theres 2 kinds a screw on and a push in. i need to know what kind would work best
Your engine is machined according to the temps it will be running, and yes, a few degrees can make a difference. It won't be imediate, more long term, but the engine won't last as long. You have to consider all the expansion that takes place when an engine warms up to know that cylinder walls aren't perfect circles when they're cold.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
