Will V8 motor bolt to V6 trans???
k....before I get people telling me I shouldn't do this, I was just wondering if this is possible. I know its not the right way to do it. I use this car as my daily driver and I wanted to drop a simple V8 carb. motor into the car and hopefully bolt it up to the stock V6 trans. Is this possible? I was just thinking that the reason people say to replace the rear end and the trans went dropping a V8 in, is because they are not built strong enough to handle the V8 power. I was planning on babying the car and not getting on it while the V6 trans and rear end was in it until I can afford to replace those because it would take me about a year to save up enough money to get a trans and rear end.
Auto or manual?
The T5 can bolt up to a 289, 302, 351 but you will MAY into problems with the input being too long for pre 1994' Windsor motors.
Originally Posted by NeoTokyo
(Post 6899028)
Im not wrong, your just offering more information.
I've commented on this before and others as well, searching would help greatly and I didnt want to get into another classic "Neo's Posts are too long!" If he uses a 94+ V6 T5 on a pre 94' motor he may run into that problem with the input shaft. I say MAY because I have never measured the other way on a V8. The 94+ are 5/16" longer if I remember correctly. OP: Being a 94' Your best bet is to buy a wrecked 94/95 GT and swap it all over, then swap over to a carbed setup if you want and sell off the rest/part out the wrecked GT. |
(Post 6901678)
I've commented on this before and others as well, searching would help greatly and I didnt want to get into another classic "Neo's Posts are too long!" If he uses a 94+ V6 T5 on a pre 94' motor he may run into that problem with the input shaft. I say MAY because I have never measured the other way on a V8. The 94+ are 5/16" longer if I remember correctly. OP: Being a 94' Your best bet is to buy a wrecked 94/95 GT and swap it all over, then swap over to a carbed setup if you want and sell off the rest/part out the wrecked GT. NM for some reason I read the being as bearing. It is actually .67 inches so about 11/16 difference in the input shaft. The 94+ is 7.85 while the older are 7.18 |
I'm actually talking about using the stock transmission that is in it now. Its a 2000, 5 sp. I just wanted to know if a 289 or 302 V8 carb motor will bolt right up to the transmission I have in there now.
Also, are you guys saying that the transmission that comes stock on a 2000 V6 is a T5 transmission? |
I re-read your post and I'm getting confused. So a 289 or 302 (no matter the year) will bolt up ok without problems? I'm not interested in the 351. Just checking. thanks
Again, as long as you use a 94/95 GT bell housing yes it will.
k....Thanks
What about the oil pan. Would that clear everything ok or would I need one off a 94/95 302? |
