Rear end made a loud pop...
And now my car is pulling to the left a little bit, and it has wheel hop when I'm turning to the right. When I turn to the left, I hear the same loud pop. What the hell is that? It's a T-Lok with 4.10s
Spider gears.
Guess now is the time to try and convince the parents to co sign on a loan for a GT... anyone want anything from a cammed sixxer? hahaha
I want UD pulley if your engine is externally balanced.
It is. and if this actually happens, haha it comes with belt, water pump pulley and crank pulley/harmonic balancer
EDIT: Driving on bad/broken spider gears is a no no right? hahaha I need to get to work... |
I would say that it is a bad thing.
I had a buddy that knocked off all but 3 teeth on his ring gear. He drove it around. |
Oh wow haha. I want to fix this now... aha
Driving with broken spider gears is a no no.
Fix it before you cause more damage. I want the cam and windstar upper lol |
could also be a control arm bushing. when i had a solid rear in my car i had the steel sleve break loose from the rubber and clunk and make al kinda noise. first check the bushings the n pull the cover . spider gears are a walk in the park to replace .
Taking it apart to look tomorrow! do I have to pull the differential to replace spider gears?
