rough idle with no power
HELP!! I have changed everything you can think of on this car and it still does the same thing, idles rough(around 850 RPM) when you give it gas there is no power, after a few seconds of feathering the gas petal it revs up. Changed or tested the coil pack,spark plugs,wires,T.P.S.,crank sensor,camshaft sensor,EEC,oxygen sensors(4) any suggestions will be appreciated.
It,s a '95 with 180,000 miles the only modifications are dual exhaust the check engine light is not on I tried dropping the exhaust to see if it was clogged cat-alack converters this changed nothing I'm starting to think it might be clogged injectors, the fuel pressure is where it is supposed to be
zanemoseley
09-06-2015 12:58 PM
