I've changed my fuel pump and fuel filter, engine tries to fire seems to want to start, the service engine light is NOT on, any help would be greatly appreciated
Open inlet air duct by airfilter, spray in a shot of starting fluid while someone cranks engine. I it fires and runs a few turns, you are not getting fuel to the injectors. If these cars have a fuel service port (Schrader valve), borrow or buy a fuel pressure gauge, check for proper fuel pressure. Can you hear the pump turn on for a few seconds when you turn on the key? imp
I've got fuel to the Schrader valve, I don't have gauge (any ideas what the pressure should be) I can barrow one. Starting fluid gets it to hit a little bit, I'm leaning towards a sensor or something like that. Back story, car sat for 6 years I got it running, it ran good for about a week, then suddenly won't start.
I'm baffled?
