why,why,why,why,why?
#22
RE: The long answer
ORIGINAL: Blue Oval
the answer is simple, put it in neutral, rev it a bit, and then put it in drive. even works for my 105hp corolla. not good for your trans tho
#25
RE: The long answer
I had to get my tranny on my 6er camaro rebuilt
the auto tranny also starts off in second gear, take off slowly, and at about 7 m.p.h push it to the floor and you will feel it downshift. pull it down to first gear, and floor it you will have atbout 10 ft or if its raining atleast 30 ft.
btw if O/D is off does it start off in first gear ive, never tried it.
#26
RE: The long answer
i dont burn out- ever. wide tires are too expensive. but if i wanted to, in my auto, just brake with left foot, gas with right and at about 1500rpms (stock) it will spin, or now it is more like 2200rpms before i can turn the tires with the brake and gas on.
