MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   V6 (1994-2004) Mustangs (https://mustangforums.com/forum/v6-1994-2004-mustangs-4/)
-   -   Door Lock doesn't work properly (https://mustangforums.com/forum/v6-1994-2004-mustangs/619121-door-lock-doesnt-work-properly.html)
thewalesaver Oct 4, 2010 04:51 PM
I've had a problem with my '01 for about a year now where the lock on my car door will most of the time not go down or come up when I use the key remote or the lock/unlock button inside the car. It started happening on the driver's side door only because my friend sat in the car and held the lock down while I tried to unlock it using the remote.
When I try to unlock/lock it with the remote or the button inside, it goes up/down halfway and then goes back up/down to it's original position (so pushing the lock button leaves the driver's side of the car unlocked and vice versa), like it wants to unlock/lock but it doesn't. On rare occasions, it will make it all the way to the unlocked/locked position but, usually, it doesn't.
I'm tired of having to remember to push the lock down before I get out of my car and close the door or having to use the key to get in the driver's side. What should I do to fix this?
SON1C Oct 4, 2010 05:33 PM
I have pretty much the same problem with my 01 driver side door.
WoahPony Oct 4, 2010 07:53 PM
take the interior panel off and make sure its still attached correctly to the rest of the locking assembly? other than that I dunno
d.girardi Oct 25, 2010 11:02 AM
When I bought mine, I had to unscrew the thing that goes up/down when you unlock/lock it just a little bit. I know with mine it was screwed on too tight and the lock wouldn't go all the way down and catch so it could stay down.
srsbzns99 Oct 25, 2010 07:38 PM
i had the same problem with my '99 mustang but on the passenger side
my problem was the actuator, cheap and relatively simple to install
haystackstang Oct 26, 2010 07:26 PM
its your power door lock going out mine does the same except on the sn95s its passenger side
© 2026 MH Sub I, LLC dba Internet Brands
