Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
- Ford Mustang V6 and GT 2005-2014: How to Replace Fuel Pump
Step by step instructions for do-it-yourself repairs.
2001 3.8 replacing fuel pump and other question
Fuel pump died in a 2001 3.8
However key on, engine off no power to pump from CCRM.
I gave the pump 12+power to its power wire-no sound just a spark, so I know its dead.
My concern, is after, replacing the dead pump, the no power issue, and im kinda new to these newer years, just need to know how to remove the pump and what to look for, as far as the CCRM Location and testing for the no power.
Couldnt find a TSB or article, but heard this is a common issue.
Car runs fine on ether
Try the V6 section.... but usually on the 3.8 fuel pumps, it's the hose right on the pump that splits. It kicks the fuel right back into the tank instead of up to the motor. It's not actually a pump going bad. Removal is easy. Drop the tank, unbolt the lid from the top of the fuel tank and pull the pump out. It will take about 2 seconds to see if the hose split or not.
Design1795
01-24-2017 10:38 PM
Design1795
08-24-2015 04:41 PM
