Engine surging while defrost is on?
Cool...starting in Jan I will be on the NW side everyday going to Lincoln Tech. After we see how bad this surging is maybe you should bring it my way so I can get a closer look at it. I live over in New Castle, about 40 miles from 465 right off 70E.
I had the same problem
I had the same problem when I would turn on a/c in summer and defrost, heat on vent or mix in the winter but in floor it didn't surge. I changed the IAC and EGR valves no go, changed the serpentine belt with no change. So I went to a Ford dealer and had the a/c charged with no change. So my last step was to change the Compressor Clutch Cycling Switch and wala my problem is gone. Now I did have a tech say I can change it without losing refrigerant not the case. Hope it helps anyone who was going nuts like I was.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
