Ford Racing Aluminum Driveshaft (1998) and Tuner
Old 05-05-2016, 11:05 PM
98CobraV6
98CobraV6's Avatar
Default Ford Racing Aluminum Driveshaft (1998) and Tuner
Hi am thinking about buying the ford racing aluminum driveshaft for my 3.8L mustang. I also want to get a tuner but it's about 100$ more and I want to work on my car asap.. so I am wondering if anybody has installed the aluminum driveshaft and what gains did you get? Also, would a tuner be way better? What gains can I see from getting a tuner?
98CobraV6 is offline
Old 05-06-2016, 10:59 AM
PNYXPRESS
PNYXPRESS's Avatar
You will see minimal gains on a otherwise stock car from the driveshaft.
A tuner would be your best first mod
PNYXPRESS is offline
Old 05-06-2016, 08:13 PM
KrazyKen
KrazyKen's Avatar
Don't forget the subframe connectors and rear sway bar if you have not already done this. Helps out a lot on the convertibles.
KrazyKen is offline
Old 05-07-2016, 08:17 PM
Daehawk
Daehawk's Avatar
It would help but everything you do will add up . The driveshaft is stronger than the factory steel one and weighs maybe 5-8 lbs less. Its also rotating mass which is a big difference compared to static mass elsewhere in the car.
American Muscle just put out a video on the exact driveshaft for your car from Ford Racing if you are interested. Ill post the video link for ya. If you do go this route dont forget to get the correct spline one for your car.
Daehawk is offline
Topless Stang
04-18-2016 02:23 PM
08hybridok
04-13-2016 01:34 PM
Topless Stang
04-08-2016 08:36 AM
Burtonsnow157
04-07-2016 02:24 AM
Quick Reply: Ford Racing Aluminum Driveshaft (1998) and Tuner
