Good measurements for tires
Old 08-01-2013, 01:58 AM
AFord$$
AFord$$'s Avatar
Default Good measurements for tires
I basically want fat wide tires in the back and smaller ones in the front... I only got 17" rims so there's alot of space... What would be some good dimensions to get?
AFord$$ is offline
Old 08-01-2013, 05:41 PM
LilRoush
LilRoush's Avatar
17" part doesn't matter. What is the width of them?
Typical is 17x8 - which means you are limited to about a 255 width tire (255/40/17 would be the full size number you want to look for).
If want true bigs/littles to look like a drag car, you'll need to get different rims.
LilRoush is offline
Old 08-01-2013, 06:08 PM
Dr.Le
Dr.Le's Avatar
Right, or you can get hub-centric spacers for the rears. that way you can rotate the tires and make them last way longer. (tires costs tooo much!)
Dr.Le is offline
Old 08-01-2013, 10:38 PM
AFord$$
AFord$$'s Avatar
what do u boys think of 255/75/17 in the back and a skinnier/75/17 in the front? If not your sayingg fat tires wear out? What would be a better width?
AFord$$ is offline
Old 08-02-2013, 03:13 AM
AFord$$
AFord$$'s Avatar
okay i got some 225/65/17 good years.... thoughts? tips? what about spacers i heard 13s are good...
AFord$$ is offline
Old 08-02-2013, 12:09 PM
Dr.Le
Dr.Le's Avatar
do you mean 45 and not 75?
its not the fat tires wear out, its that tire rotations are good for tires and gives them a more even wear and so they last longer. its what you're suppose to do, according to mainstream automotive maintenance.
but us enthusiastic drivers will sacrifice lots for things for speed, power, performance or even looks.
i think what you're set refers to is called a staggered set up (when the two back tires are bigger than the two front tires)
What is you're goal for a staggered set up? looks or performance?
I think in a staggered setup, there will be better stability b/c its wider and more tires means more rubber contact to the ground so there's more traction.
BUT in order for a true staggered setup, your rims will "HAVE" to be different size. If you have the same rim size, lets say 17x8 the biggest difference may be somthing like this:
255/45/17 back and 235/45/17 but these are really bad setup and you're pushing the limits of your rims and it will perform poorly and even look bad. (safety issues too)
so its hard to give a useful response w/o knowing you're goal.
but in general, getting the right tires for the you're rims.
Dr.Le is offline
Old 08-05-2013, 07:49 PM
The grey beast
The grey beast's Avatar
This is a personal opinion only, so take it how you wish. But I either would not recommend spacers at all, or recommend very small ones because if your rims/tires stick way out past the fender-wells it doesn't look very good at all. There is a 2000ish Camaro here in our town that has huge spacers on it and narrow tires and it looks just plain dumb
The grey beast is offline
Old 08-06-2013, 02:20 AM
Daehawk
Daehawk's Avatar
LilRoush, what are those tires on the black Mustang in your sig?
Daehawk is offline
Old 08-31-2013, 02:11 PM
AFord$$
AFord$$'s Avatar
I ended up with 245/55/17 in the back... 225/55/17 in the front
AFord$$ is offline
Old 09-01-2013, 08:10 PM
Dr.Le
Dr.Le's Avatar
pics please.
Dr.Le is offline
Quick Reply: Good measurements for tires
