Danielsmustang |
03-27-2012 01:32 PM |
This is what happens when you rebuild an engine wrong..
ok, this is probably my last post as this car is getting me to the point where i want to blow it up. Im going to explain everything, for those who don't know the tragic story of my stang. i had messed up the oil pan around a month back. i decided it was time to to everything i wanted done to the car ( which wasn't much) so i dropped the engine, dropped the tranny. Replaced the oil pan, replaced the throwout bearing. When i was tightening up the headers, one of the bolts had broken. so my neighbor, which is a mustang fanatic, had told me to fix it because i was going to have an exhaust leak. so i decided to drill the bolt and de tap the thread. In our attempt to do so, it passed the bolt and broke through the head. i didnt realize this. We put the engine back and everything was working fine besides the point that the car was overheating and throwing out water through the header bolt. So off comes the heads. I got a new head, took both heads to the shop, had a valve job and resurfaced. I put everything back, and the car started but soon died. We thought it was an air leak because the lower intake had three broken bolts ( the ones that tighten the upper to the lower). So i took them to the shop, had them remove it, and yesterday i put everything back. i turned the engine and it doesnt want to start. BUT when it does, it dies after like 3 seconds of idleing. It has a bad shake right after the engine dies. And if i touch the gas pedal it dies instantly. Could it be a sensor? a big ass vacuum leak? or something mechanicaly? because truthfully, i heard the engine make some noises that didnt sound quite proper. I cant describe it but i know it wasnt healthy. But when the car idles, it idles fine, but after 3 seconds it dies. its not fuel or timing. So maybe, electrical? or vacuum? or mechanical? I mean i dont see how it could be mechanical as the rockers where tighten to 28lbs of torque which is spec. so if you have any idea please help me out. I need to have this car up by this week, and im literally about to just cut my losses and call it a day.
