Help needed diagnosing a chirping noise in the engine bay!
Does it speed up with engine rev? It could be anything that moves..tensioner, alternator bearings, the belt, water pump,. I picked AC cause when the video moved that way it was louder...but it may be because you were closer. I'd still even though done recheck the tensioner and belt. Might try getting a little wd-40 on all the pullies. Dont get it on belt of course lol.
If you remove the top from the synchronizer and spray a a small amount of lubricant on top to allow it to drain into it. Put the top back on and start the car. The noise will go away, but temporarily. This lets you know it is the synchronizer. It is a very high pitch squeal, that is very hard to ignore. I think the part is around $65.00.
