How to replace a passenger side 02 sensor
Hi, I'm trying to figure out how to remove and replace the passenger side (upstream) o2 sensor on 3.9 v6 its a winsor engine if that helps. I can't get to it from the top or the bottom, so I'm kinda stuck All help is appreciated
I'm almost positive I had to take the wheel off to get to the passenger side, but it's been awhile since I've owned a Mustang. The driver side was easy compared to the passenger. Did you at least find the o2 sensor, you may need a flashlight!!
P.S Now that I think about it, I don't think you have to take the tire off, you should be able to get to it, maybe someone else will chime in who has done it recently.
Sometimes shops will wanto/have to remove a part to gain better access but I have seen many time them get a hellashis grip on it with that special O2 wrench that increase it grip as you put force on it. Kinda reminds me of a pipe wrench as it can get a real tight grip. I have used an assortment of flexible extension pieces snapped into an impact wrench too. It can be a pain in the ***. If you guys remember back when i did my 4 sensors, that one took me 3 weeks to get off because of my limited amount of person tools.
bryan616fl
01-25-2019 09:07 PM
