Last edit by: IB Advertising
Browse all: General Overview
- Ford Mustang V6 and GT 1994 to 2004 Why Isn't Key Fob Working
Guide to diagnose trouble and recommended solutions.
95 3.8l key fob loses programming
So when I bought the car it didn't come with a remote or keys to the door. It came with just the ignition and trunk key. Which are the same of corse.
So I bought a fob online. It's older and seems better days but it worked. I was able to program it no problem and it worked fine. Until I redid the water pump.
The power was undone for maybe a week on it. Then I drove the car home and noticed it didn't work. I reprogrammed the remote and carried on with. My biz. Well today, it lost its programming again. If I reprogram it, then maybe an hour later, nothing. I reprogram it and it's fine and then later, it fails.
Problem is, no keys for the doors. It gets locked and the remote stops working, I'm screwed.
Anyone know a place I can get new door locks for this thing? That would solve half the problems
Most lock smiths can make a key for you without having to take the lock out. I locked my keys in a work truck once and the smith came out and had some kinda feeler tools he poked in the lock and sat there and cut a key to use to unlock the door.
I have learned how to pick locks with a regular set, but thats only padlocks, not car doors. Not to mention I am a felon so having a pick set isn't good for me.
And wouldn't you know it. My mobile locksmith is out of town til the 24th....ugh.
I called around and there isn't a single person other then the guy outta town, that can do this stuff. The only other place told me i'd need to remove the lock from the cardoor for them to do it.
The ignition key does not match the doors....it matches the trunk but not the doors.....
And I think the keyfob issue could be a ground. It works fine as long as the car sits, but if I drive it, hit a few bumps, its game over. Has to be programmed again,
lincolnshibuya
12-08-2015 04:37 PM
logan409
09-26-2015 07:43 PM
