Dim Passenger Side Headlight
Hi,
I own a 2004 Mustang V6 40th Anniversary model and recently noticed that my passenger side headlight is much dimmer than the driver's while in normal mode. As I checked the light, I noticed that the clip connecting the harness to the bulb was broken. But after checking, I realized that was not the problem so I changed both bulbs with new factory ones to see if that would fix it with no luck. What can be the cause of this?? All other lights/electronics function normally with no surges. Thanks, Alex |
Ballast?
Originally Posted by Daehawk
(Post 8073919)
Ballast?
Yes sorry..so used to HID questions.
I'd guess it's a ground issue. Maybe loose but best guess is the ground on that side. |
No problem, I checked the 2 grounds that are on top of the frame, cleaned them and made sure there was a good connection... are there more grounding points I should check? If so, where are they located because I cannot find any diagrams/photos of the headlight grounds online...
Thanks! |
I've looked also and the one diagram I found was all in color and stuff but was so small i couldn't read it. Sigh. I do not know how many there are or where but the dim output in only one side and even wit ha new light definitely is a ground in my opinion. maybe someone on here can chime in folks?
Check the attachment point again at the back of the headlight housing. Those black plastic clips tend to heat up and warp over time...it allows the ground to come loose at random. Even if the wire is tight in the back, it might have lost full contact inside the clip/harness. The pigtails can be picked up at most local parts stores for about $5 each.
Originally Posted by LilRoush
(Post 8075315)
Try pushing the wires in and out of the harness ends a bit, see if that helps.
(Post 8075305)
- Take a safety pin or thin needle and back probe the low beam power wire in the connector - Touch the negative lead of the multimeter to the positive battery post and the positive lead to safety pin. You should get no more then 0.5 volts. Any more then that and you have resistance somewhere between the pin and the positive battery post. - Take the safety pin and back probe the ground wire. - Touch the negative lead of the multimeter to the negative battery post and the positive lead to the safety pin. You should get no more then 0.5 volts. Any more then that and you have resistance somewhere between the pin and the negative battery post. Resistance can be any number of things, including but not limited to loose and/or corroded connections or damaged and/or corroded wires. To find the point of resistance walk up the wire towards the battery with the positive lead until you get a reading you expect. The resistance is between the first point that produces a reading you expect and the last point you got a bad reading. Note: I said to touch the battery post with the multimeter lead, not the battery terminal. This is because the resistance can easily be in the battery terminal (loose/corroded connection). Good luck... |
