Acceleration Problems
Old 12-12-2012, 10:47 AM
sickofstupidity
sickofstupidity's Avatar
Default Acceleration Problems
I bought a 2003 Ford Mustang V6 with about 180k miles on it. The guy kept good care of the car. Well at least the exterior of it. I have had it for about 2 months and lately I have noticed that it is having problems with that burst of speed. It jerked/bucked on me while accelerating to get onto the interstate one time but it has never happened again but I have noticed a decrease in response time from the time I hit the accel pedal and when the car speeds up. I started using premium gas in it since I have had it. I'm not sure if I screwed something up or not. I am concerned about the lack of pulling (acceleration):
fuel related?
transmission related?
engine related?
exhaust related?
Any ideas?
sickofstupidity is offline
Old 12-13-2012, 07:24 AM
Ironhandx
Ironhandx's Avatar
Whats done to the car? What gear were you in when it happened? Did it happen right after you were shifting gears?
Is the transmission manual or automatic?
Ironhandx is offline
Old 12-13-2012, 10:10 PM
robb15033
robb15033's Avatar
-Always replace the fuel filter every oil change or every other, depending on type of oil used and recommended intervals of change. (Twice a year maybe).
You HAVE TO replace the ignition parts now as a good start to a preventive maintenance program & help eliminate or second guess yourself. Copper spark plugs at the very least. Plugs, wires and ignition coil at the most.
-Check for vacuum/air leaks around upper intake and around engine bay.
-With everything checked out and good to go, give it a Seafoam treatment. One can in the gas tank, more importantly, one can sucked up into engine while running through any vacuum line or straight through pcv valve.
robb15033 is offline
Old 12-15-2012, 10:13 AM
LilRoush
LilRoush's Avatar
Higher octane fuel does nothing for you - especially if you aren't tuned for it. You can skip that.
A cough / sputter could have been anything from a little water in the gas to a missed spark.
I'd start by pulling out the spark plugs and checking them for wear.
Also check to make sure your airfilter is clean.
Huh?
LilRoush is offline
Old 12-17-2012, 04:58 AM
sickofstupidity
thanks guys this is REALLY GREAT INFO!!!!
zsmart
Convertible Tech
02-29-2016 08:33 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
MasterLanMan
09-13-2015 08:21 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Acceleration Problems
