Cheapest way to make it sound great?
I want to know what's the cheapest way I can make my Pony sound gritty, rough, or throaty. I heard about the magnaflows. I have a broken cat and a messed up 02 sensor. What should I do? I'm 17 and I need to know the cheapest ways to make this happen.
There are two cats per side (4 total), two O2 sensors per side(4 total).
Any work to be done, if not by yourself, should be done by a garage that is a custom to welding (Not Midas, ect..).
-You will need to take care of replacing both O2 sensors or at least the one gone bad.
-Here is an option to replace all 4 cats for just two:
-The very cheapest way would be replace the single cat and single O2 sensor, then install one Flowmaster muffler. Off set inlet/outlet 2.25 muffler will slide right on.
-Go to youtube and listen to all the different mufflers. for the V6, usually a "chamberd" muffler sounds best. With Flowmaster, the lowere the series number, the louder it is. Example: FM Series 10= loudest. FM Series 50=quietest. The 10 sounds great, the 44 is great, the 40 is nice, and so on.
-The cheapest way to get a dual exhaust could be to replace the O2 sensors, cut out the two "after cats", and run straight pipe to two mufflers of choice.
