Oil leak
Old 02-23-2013, 01:17 PM
$cactuskid
$cactuskid's Avatar
Question Oil leak
Can someone tell what the sensor is, located on the drives side of the engine, in a small opening behind the power steering pump? It is leaking oil and I want to change it. Also, what is the best way to get to it?
Thanks
$cactuskid is offline
Old 02-25-2013, 08:41 PM
Gearsallday
Gearsallday's Avatar
Is it on the valve cover?? If so thats your driver side p.c.v which in your model year there is a defect in the the valve cover ( either it has a crappy baffle or doesn't have one at all i can't remember) so in stead of just oil vapor being sucked through it you'll suck up some oil as well.You can do a bunch of things starting with getting a set of valve covers from an 03/04 and changing the valve or you can replace the valve and install a catch can.
Gearsallday is offline
Old 02-26-2013, 06:16 AM
petrock
petrock's Avatar
On my wifey's '98, the wholes in both the valve covers are for the PCV system. The whole in the driver side valve cover is where filtered air gets sucked into the motor. So it can't suck any oil. The whole in the passenger side valve cover is the one with the PCV valve in it and is the one that has vacuum that sucks air from inside the motor into the upper intake manifold. It is that one that commonly sucks oil.
So if your problem is the whole in the drivers side valve cover, then you probably just need a new rubber grommet if the tube is not cracked or damaged. rockauto.com sells replacement grommets. Good luck...
petrock is offline
Old 02-26-2013, 07:26 PM
$cactuskid
$cactuskid's Avatar
Default Oil leak.
Thanks for the replies. No it is not in the valve cover it is down in the block right behind the bracket that supports the power steering pump.
Old 02-27-2013, 02:48 AM
petrock
petrock's Avatar
Does it crew into the block? If so it might be the oil pressure sensor. But without a better description it is hard to say. A picture would speak 1000 words.
petrock is offline
Old 04-07-2016, 11:30 PM
$cactuskid
$cactuskid's Avatar
Yes it screws into the block.
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
jerrytubes
10-23-2015 12:11 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Oil leak
