Seat Belt Warning
Old 02-19-2014, 08:42 AM
lksfast77
lksfast77's Avatar
Default Seat Belt Warning
Even with my seat belt buckled, the warning light keeps beeping.
I found this instruction on how to reset it and went through the process yesterday. But again today it started beeping in intervals.
Below are the instruction, What else can i do to make this stop.
Step 1: Turn ignition switch to ON. All the way forward without cranking the engine.
Step 2: Wait until the seatbelt alarm to go off and stop. About 1-2 min.
-- Steps 3-5 must be completed within 60 seconds or the process with have to be repeated.
Step 3: Buckle then unbuckle the safety belt three times, ending with the belt unbuckled.
Step 4: Turn the headlights on then off.
Step 5: Buckle then unbuckle the belt three times ending with the belt unbuckled.
--After step 5 the safety light will be turned on for about three seconds then go off.
Step 6: Within seven seconds of the safety belt light going off buckle then unbuckle the belt again.
--That should disable the safety alarm if it is currently activated or vice versa. You will see the seat belt light blink a few times to confirm it has been done successfully.
lksfast77 is offline
Old 02-19-2014, 06:49 PM
mustangman02232
mustangman02232's Avatar
Make sure the parking brake is set, you might have to just buckle and unbuckle it ten times to I believe is the other procedure but I think that is only newer fords
mustangman02232 is offline
jrrhd73must
10-02-2015 09:17 PM
Explosive
10-02-2015 07:45 AM
ChampInSD
10-02-2015 04:55 AM
GT350 S550 Tech
09-29-2015 03:29 PM
Quick Reply: Seat Belt Warning
