how hard to change valve cover gaskets on 01
Old 03-18-2014, 02:11 PM
massguy54
massguy54's Avatar
Default how hard to change valve cover gaskets on 01
I have to replace the valve cover gaskets on my 2001 ,how hard is it to do
massguy54 is offline
Old 03-18-2014, 06:37 PM
warthogdriver
warthogdriver's Avatar
Its not hard at all.
If you have dpne things like brakes such its cake.
Just tag anything you have to move out of the way...plug wires...connections...and such.
Just look up the torque on them so you dont bend them.
Maybe a haynes or chilton guide would be helpful as well.
warthogdriver is offline
Old 03-18-2014, 09:06 PM
jthorn9
The Godfather
jthorn9's Avatar
Not hard, just time consuming, especially if you've never done it before. A pro could do it in around 2-3 hours, first timers, expect around 5.
jthorn9 is offline
Old 03-19-2014, 09:19 AM
PNYXPRESS
PNYXPRESS's Avatar
Drivers side is easy, only thing in the way is the coil pack.
Passenger side is a little harder to get to as you have to remove the intake tube and throttle body, and then you still have to wiggle it out carefully from under the upper intake
PNYXPRESS is offline
mirandaandjimmy
11-16-2015 08:51 AM
YoungStangsMan
09-05-2015 07:01 PM
teeeeg67
09-01-2015 11:53 PM
KEM Motorworks
08-14-2015 10:13 PM
Quick Reply: how hard to change valve cover gaskets on 01
