KEYFOB HELP! I am about to give up.
Old 09-05-2014, 02:24 PM
modded_v6_04
modded_v6_04's Avatar
Default KEYFOB HELP! I am about to give up.
So, starting from the beginning. My key fob just randomly stopped working. So I got a new one and a new battery from Autozone. We did the key fob test thingy and my old one would not respond at all. Well my new one will NOT program.I tried to do what the manual and others have said, turning it on and off 8 times to turn on programming mode. I get the to the point where locks cycle, but it nothing happens when i press the buttons on the fob. I have done everything from unplugging the battery, unplugging (From what i thought) the transmitter, i have unplugged the alternator (shouldn't matter anyways i know). I have tried everything. Any suggestions? I have a 2004
modded_v6_04 is offline
Old 09-05-2014, 03:17 PM
dawson1112
dawson1112's Avatar
Answered in your other thread, but if it goes into programming mode and wont respond to the new fob , then its the wrong frequency. Where did you get the key fob from?
dawson1112 is offline
Old 11-06-2014, 08:53 AM
mmmdaddy57
mmmdaddy57's Avatar
Default keyfob problem
Dawson is right. You must have the wrong frequency. Check the frequency on the old one and the new( it will be printed on the back cover). If you cant read it because it is worn off it might be printed on the printed curcuit in the unit. They used the same keyfob for many years and vehicles though. I bought mine through E-bay and they worked fine.
mmmdaddy57 is offline
Old 05-02-2015, 01:52 PM
01GTon18s
01GTon18s's Avatar
I know this is an older thread, but I also have a programming question maybe someone can help with. I've searched online and everyone says to cycle the key 8 time........but when I do this my car doesn't respond. Meaning that the locks don't even cycle after turning the key. Am I missing something?
01GTon18s is offline
Old 05-08-2015, 10:09 PM
01GTon18s
01GTon18s's Avatar
Found another link on the web that explained you have to manually lock you door before cycling the key 8 times. Got it fixed.
TCStangerv6
10-11-2015 05:57 PM
Matt's 95 Stang
10-05-2015 07:16 AM
KingRando
10-02-2015 08:06 AM
Florida Regional Chapter
09-30-2015 08:04 PM
Quick Reply: KEYFOB HELP! I am about to give up.
