MAF Screen in Factory Airbox - Should this have a seal?
My car is a 2000, stock intake and noticed that the MAF Screen/Strainer which is sandwiched between both sections of the MAF housing sits in there loosely. Loosely as in, it's not going anywhere but has enough room to slide around a bit.
If I unbolt the MAF from the airbox there appears to be a 'notch' or ring seal area in front of it but no o-ring or seal. Should there be an o-ring or seal in there and would this affect anything with the stock intake otherwise? I've seen some used MAF units on ebay and noticed a few of them have what appears to be a gasket or seal of some sort in front of the MAF surrounding the screen. |
I looked all thru my Mitchell subscription and there isn't a single diagram of the MAF or how is mounted. My son has the car now, so I can't check it out and I don't recall when I had it out to clean it.
Sorry, I am useless this morning! |
it should not move around, if it can move its leaking unmetered/unfiltered air, if you go to a dealers parts dept, they should be able to pull up a diagram so u can see the associated parts and get what you need
Originally Posted by jwog666
(Post 8503401)
I've tried searching pics of the stock MAF/screen setups and the only thing I can relate to is some used MAF units listed on ebay and some show a sealing 'ring' around the screen and some don't. I've carefully taken apart the airbox when I first got he car and never noticed anything falling out of there. For reference, here's the only one on I've found online that shows a seal around the screen attached to the MAF. http://www.ebay.com/itm/1996-97-98-99-00-MUSTANG-MASS-AIR-FLOW-SENSOR-METER-3-8-/111699134710?hash=item1a01c988f6&vxp=mtr |
Did a quick search of Ford's parts catalogue, and it appears they list what they call the MAF o-ring or gasket, but it's $83.00!
I can only assume that's for a bulk pack of 20 of them lol. I'll check with a local dealer and see if this is even still available, but at that price might as well source a used one somehow. http://www.fordparts.com/Commerce/Pa...&model=Mustang |
1 Attachment(s)
I think I may have found a solution:
I came across some old stock of 3M double sided tape I've had laying around and it gave me an idea. I cut it to length to fit around the screen and then folded the edges over. The screen still fits in the beveled area of the air box and I was able to carefully tighten the MAF down and looks like it's created a nice air tight seal. Once I get a chance to road test I will report back. |
looks like a clever fix, as long as it seals u are good to go
I wouldn't worry too much over this. The screen is just in case your air filter comes apart (it rarely happens, but does), or you drop a nut into the intake -- it protects the sensor probe from any FOD which might be drawn up the intake at high flow.
Originally Posted by TfcCDR
(Post 8506603)
