what are the odds - Service Engine Soon light
Old 09-30-2015, 09:45 AM
lincolnshibuya
lincolnshibuya's Avatar
Default what are the odds - Service Engine Soon light
So this morning when I started the car I was wondering where's that check engine light icon is, I can't find it! Normally it will lit up when the key is in the ON position and then turn off if there are no issues.
I haven't noticed this out until this morning, so it could be;
1. Previous owner disconnected the light to hide something before I purchased it.
2. Bulb burned out
I did a scan and no codes showed up but this is not good long term since if there are real issues I won't know until I plug in a scanner.
My best guess is that the bulb burned out and the previous owner didn't care (car run just fine) but I'm doubtful that the bulb will burn that early (it's a 2004 with 104k miles) Possibly there was a history that it was tampered prior to the previous owner.
https://www.facebook.com/diyfordmustang
lincolnshibuya is offline
Old 09-30-2015, 09:49 AM
jwog666
jwog666's Avatar
turn the key to the on position without cranking the engine, this will light the engine light, if it doesnt light, pull the cluster and replace the bulb. its burnt out, or the cluster has a fault internally
jwog666 is offline
Old 09-30-2015, 12:04 PM
lincolnshibuya
yep, that's how I checked it and immediately scanned. luckily no codes.
Old 10-03-2015, 02:24 PM
lincolnshibuya
I replaced the bulb, it still won't light. If I swap it with a cluster from a different car will the odometer show the same mileage? Kind of odd that only the SES light will not work and the rest are ok.
Old 10-04-2015, 01:54 PM
lincolnshibuya
been searching the web for answers and the answer is "not possible without dealership re-programming". the PATS is incorporated into the cluster and the swap with another car is not possible until a re-program is involved.
Old 10-04-2015, 09:45 PM
jwog666
jwog666's Avatar
yep, sounds like you need a new cluster, on the up side, its not a fault that is causing it to be undriveable. so you can budget it out a while
jwog666 is offline
Old 10-05-2015, 08:09 AM
PNYXPRESS
PNYXPRESS's Avatar
I believe you can swap clusters without an issue. A friend bought the simco gauge cluster for his 02 and didnt have to reprogram anything for it to work. And it kept his mileage.
PNYXPRESS is offline
Old 10-05-2015, 08:45 AM
lincolnshibuya
i think the simco gauge cluster retained the original electronics, it's only the faceplate that was changed. Here's the link that I used as a reference, not sure if that's the simco white face gauge cluster on americanmuscle.com.
http://www.accutach.com/94-04-ford-c...er-information
I'm going to try clean up the contacts whenever I have time.
Old 10-05-2015, 08:55 AM
jwog666
jwog666's Avatar
^ correct cluster needs a program, as a dealer tech i know
jwog666 is offline
Old 12-08-2015, 04:37 PM
lincolnshibuya
it's kind of funny, so today I opened up the cluster and found out that the previous previous owner taped the check engine light with black electrical tape inside, 2 square patches!! I suspect the 2nd owner did this because when I bought it from the 3rd owner there are no codes present (3rd owner must have fixed all the issues) and just told me that the bulb might be busted.
djbigskrilla
09-20-2022 01:04 AM
Diode Dynamics
28
05-26-2022 12:02 PM
J.casone400
08-28-2015 09:33 PM
inyadreems
08-21-2015 09:10 AM
kevans79@yahoo.com
08-18-2015 08:16 AM
Quick Reply: what are the odds - Service Engine Soon light
