D^## Fuse!
D^## Fuse!
I really need help with a fuse problem. I was getting the charge light on my 2013 v6 stang premium automatic off and on. A couple days ago I took a look at the positive battery connector and found and repaired a rusted out bolt. I replaced the rusted bolt and sanded all connecting surfaces clean as a whistle. When I connected the - terminal The front fascia lights flashed on and then quickly off and the audio warning sound in the cab made a short chirp and then died. I've looked through the Owner's manual and can't find the correct fuse for this stuff. To avoid going through all the most likely fuses one by one, does somebody know which fuse it might be? I would be most thankful for a good reply here.
THANKS!
THANKS!
Skippy5341
06-15-2016 11:38 AM
Tramac
06-14-2016 06:47 AM
