Supposedly I'm supposed to change tramsmission fluid? 02 V6 Manual
Old 07-08-2016, 07:18 AM
Rapscallion Stallion
Rapscallion Stallion's Avatar
Default Supposedly I'm supposed to change tramsmission fluid? 02 V6 Manual
I assumed everything was sealed and it would never need to be changed. Do any of you have tips on changing fluid? Type, quantity, how to change it? I've seen post about automatics, but not much about my car. Thanks!
Rapscallion Stallion is offline
Old 07-12-2016, 01:16 PM
User 92421
IN JAIL!
User 92421's Avatar
consult your owner's manual
User 92421 is offline
Old 07-12-2016, 01:22 PM
09GT/CS
09GT/CS's Avatar
Yeah just check your manual. Manual trans are pretty simple pull the drain clean the magnet and refill. Not much more than that most of the mustang manuals take between 3and 4 quarts depending on year and model but your owners manual can tell you exactly what you need and how much of it. The hardest part will be refilling most of the fill plugs are hard to get to and will require a pump from the parts store but they are cheap. And some others can be filled through the too by removing the shifter.
09GT/CS is offline
S197 GT
05-29-2021 07:14 PM
99GTvert
09-08-2016 04:48 PM
Tramac
06-14-2016 06:47 AM
ldutton6
06-10-2016 09:48 AM
jar_are_red
06-10-2016 06:14 AM
Quick Reply: Supposedly I'm supposed to change tramsmission fluid? 02 V6 Manual
