Swap Mach 1 Diff Into Gt?
Hey guys, I have some questions I was having trouble googling... Hopefully y'all can help me.
I have a 2004 V6. I swapped in a GT rear end out of a 99', guy told me it had 4.10's, but it didn't take long to realize the diff was worn out and it was still the stock ratio... Well I found some one selling the differential out of a 2004 Mach One (Not the whole rear end, just the pumpkin). How hard would it be to swap that pumpkin on to my axles?
Budget is really tight and i'm good with a wrench that's why i'm considering this, plus I have a REALLY strong desire to shorten the gears in my car (Mach One has 3.55 fyi)
Extremly involved swap,,, the 04 Mach1 uses independent rear suspension and the axles are different they use a half shaft type axle with CV joints. You'd need the entire rear not just the pumpkin. It would be much cheaper in the long run to just rebuild the rear end you have now with the gears you want.
The Cobra was the only one that had IRS for 03-04.
I'm pretty certain the MACH1 is is a Solid Rear Axle just like a regular Mustang. It just has 31 spline shafts instead of 28. The 31 spline is an upgrade for a regular GT so, if you just take the complete Axle it will swap into the GT easily.
I gotcha, yeah I think of the Diff/pumpkin as a separate piece too but to be honest, I had to confirm my gut before I responded.
Mach 1 is 28 spline stock, only difference between the two is the mach came with 3.55 gears and it was setup for larger rear rotors. So you can switch the differential from a mach 1 and install it into a GT housing just fine and still use the GT axels
