Wiring Fog Lights as DRLs...
I have a 1998 Mustang Convertible that does not have factory fog lights. I purchased a set of factory fog lights to install, but I also purchased low wattage LED bulbs (only 4w). I'd like to have them on ALL the time (like DRL's) and I was looking for suggestions as to what wire might be the best/easiest to tap into to run them. At only 4 watts each, I don't think I have to worry about a huge draw on any electrical system, so what might be close to the front end and under the hood? Thanks...Art
You can have them come on with ignition. There are plenty of fuse locations you
can wire them to, so they are on when the engine is running, key in the
RUN position. No, I won't look it up, you can do that....
