Weird Squeaking Sound
Old 12-10-2005, 10:47 PM
03YellowPony
Default RE: Weird Squeaking Sound
ORIGINAL: istambay1217
IT WORKS SO FAR!!
Thanks Yellow
I did it first thing friday morning when i put the new oil in it squeall for like 3 minutes (longer than usuall) then it stop. Saturday morning when start it up nope quiet as a mouse there is still a few whining noise now and then but you really have to listen to it for you to notice it.... For Other people reference this is what i use
for flushing GUNK Oil Flush (kerosene base)
Mobil One Motor Oil 5W-30W
Duralube for additive
I Know that maybe there is still a problem with my Camshaft bearing but at least i could wait till after christmass to address the problem THANKS AGAIN YELLOW
Mind you, it IS a temporary solution. But if it gets you by til you can to the top end, GREAT! When you do the cam, get a race style, and you might want to look at a stage 2 set of heads from supersix...hewhe. They have a cam and heads kit that will do you nicely!
03YellowPony is offline
Old 12-10-2005, 11:54 PM
ByPopularDemand
See 03 knows his **** for being the official V6 post *****
ByPopularDemand is offline
Old 12-11-2005, 12:00 AM
matthockey32
I ♥ Acer
yep, he's a ****
matthockey32 is offline
Old 12-11-2005, 01:36 AM
03YellowPony
ORIGINAL: matthockey32
yep, he's a ****
*blushes* Awe gee thanks guys!![8D]
Old 12-12-2005, 11:37 PM
istambay1217
oK GUYS just an update on whats causing the squealing sound...
i went to my dad's house in sandiego and luckily my dad's neighbor and friend is a mustang lover and restorer i told him about the problem i had, he listen to the noise (there is still some soft whining noise coming from the timing belt cover) and told me what is wrong is not the timing chain or the camshaft bearing its the CAMSHAFT POSITION SYNCHRONIZER he took one from his wife mustang (his wife pass away earlier this year) and put it into my car and sure enough even the soft squealing sound is gone....
He told me he has seen people tearing up there engine fearing its the camshaft or the timing belt that is making that sound but all you need to do is get a $20.00 stethoscope and listen to the sensor and you would know its only the sensor assembly that is bad... Well needless to say the at least 2 days work of tearing down the engine was reduce to 30 minutes procedure....... Now my only problem is getting my own SYNCHRONIZER ASSEMBLY so that i could return his.....
Just taught i share this to you guys Thanks again for the HELP
istambay1217 is offline
Old 07-19-2007, 04:11 PM
SilvrStang
SilvrStang's Avatar
I grabbed my Haynes manual and took a look and heres what it says
CPS is mounted adjacent to a pulse wheel located on the crankshaft. The crankshaft sensor monitors the pulse wheel as the teeth pass under the magnaetic field created by sensor. I took a pic with my cam as well hopefully it kinda helps.
SilvrStang is offline
Old 01-17-2008, 07:57 PM
skom2
hi guys, i'm having the same problem. mine is a v6 02 with 35k.
Is it expensive to do the sensor thing?
let me know please
skom2 is offline
Old 01-18-2008, 08:47 AM
red3.8_96stang
https://mustangforums.com/m_3560365/tm.htm
Get a synchroniser out of a wreckers yard for about $50. You need to retime the replacment unit though.
Got a CEL on ?
ATB Steve
red3.8_96stang is offline
Old 01-14-2018, 10:31 PM
torsiondrummer
Default Could this be the same sound
So in theory, my sons 2002 GT 4.6 L is a Tremec TR-3650. Would anyone be able to help me diagnose this engine sound? Is it a clutch issue?
torsiondrummer is offline
Old 06-30-2018, 12:31 PM
wwthud
Default Chirping sound, not the belt
Sounds like a cam position sensor drive (very common) on these. It is mounted where the distributor used to be and is easy to change, just make sure to use the tool provided to index it or it will not run well. You're lucky it isn't a 94. The drive for them is getting hard to find and cost is over $150 with a core to exchange (if you can find one). Good luck with your car.
wwthud is offline
GimpyHSHS
03-12-2018 04:16 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
mungodrums
The New S550 2015-2020 Mustang
09-28-2015 10:54 PM
Quick Reply: Weird Squeaking Sound
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
