Engine whine.. help
Engine whine.. help
My car has an extremely irritating whine coming from the engine and i can't figure out what it is. It gets louder and the pitch goes up when i accelerate. Also, when i am idling the RPMs kinda go up and down.
I noticed the alternator kinda has a whine when i open the hood, so i took it to autozone so they could check it. The test said the alternator was good, but it had a bad diode..
I'm confused as to how the alternator is "good" but has a bad diode. do you think this is what is causing the whine? Is there anything else i should check?
Whines and squeals are usually associated with a pulley somewhere.. The power steering is a good start, make sure it's topped off.. Check idler pulleys for squeals after that.. It would help if you had a sound clip or video, there's so many different kind of "whines"..
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
