Finished Installing my Stage II ProCharger!
#31
RE: Finished Installing my Stage II ProCharger!
ORIGINAL: Puleo76
my 86 mustang svo had a stock boost of 15 psi w/ the premium switch on and 9 psi w/ the switch set to unleaded... i LOOOOVE BOOST!!! LOL
http://www.svoca.com/mainframe.html
My long-term plans involve pulling the engine and doing the 4.3 bore job, while lowering compression a bit (though probably not as much as SSM recommends). That probably won't be for another 3-4 years, though. After that, I'll probably upgrade to the D-1SC and see how far I can push the boost.
#32
hey flapjack I might be interrested in buying the K&N CAI. Send me an email of how much you want for it groyar@yahoo.com
Thanks
Thanks
#36
ORIGINAL: onefastv6
you should get a vid from inside the car driving around.
THat would be SWEET!
when are you gonaa get the dyno results?
Doing the math, even the 11 psi pulley will not get me to the stock absolute pressure that a 9 psi set up at sea level would.... but it's pretty darn close!
Sea Level
14.7 atmospheric pressure + 9.0 boost = 23.7
Colorado Springs (6400ft)
11.9 atmospheric pressure + 11.0 boost = 22.9
Still about 1 psi off.....
So when I get my final numbers from the dyno and the track, be easy on me. Since I'm in the military, I take quite a few trips out of town. Hopefully one of them will bring me a bit closer to sea level!
Dragonus18
09-09-2015 01:21 AM
kawiguy827
09-01-2015 07:09 PM
