cold air intake
RE: cold air intake
ORIGINAL: Traken
Yeah, when you order one, you'll give the place you order it from your computer code and certain info about your car they'll want to know, such as existing mods. They will program the tuner for you. All you'll have to do is plug it in, and push a couple buttons, and you'll be good to go.
Yashar--Thanks for reading my mind!
RE: cold air intake
ORIGINAL: JStang78
Talk about coincidence! I was actually Googling the 'net for this very info today. They say they come pre-programmed with like three or four codes in the literature, but they never tell you if there's anything else, or specialized knowledge necessary, to do this. Do these pre-programmed codes set everything? Like one of the guides I was looking at had all these different categories, i.e., idle rpms, fuel/air ratio, etc. Or are these things that need to be set separately?
RE: cold air intake
Traken -- Awesome! Thanks!
I think my mind is made up. Just in case...you know...Murphy's law... one thing I found out during my search that, if nothing else, there's an SCT dealer with a huge dyno set up in the next town over from me.
RE: cold air intake
ORIGINAL: JStang78
Nice. A custom tune from a dyno shop is always better than a canned tune. That's very cool that you have one close.
RE: cold air intake
ORIGINAL: jtstudley
What happens if you dont get a tuner but install the CAI anyway?
If you install the CAI without a tuner, you will mess up your a/f (air-to-fuel) ratio. Basically, the larger inlet pipe and the colder (and therefore denser) air that a CAI provides means your engine is pulling in a greater amount of air than it did stock. In order to compensate for this increase, your computer needs to know to add more fuel to the mixture as well.
I never even turned on my car with the CAI until the tune was loaded (based on advice from Doug at Bamachips), but I can tell you what I've heard about potential problems you'd encounter. First, you wouldn't get the benefits from the CAI because the lack of sufficient fuel would hold back your performance gains. Secondly, you might encounter sputtering in your engine, and potentially even stalling, especially at WOT (wide open throttle; i.e., gas pedal all the way to the floor).
Bottom line is: either get the tuner or install a CAI that's specifically engineered to work with the stock computer.
Tim
RE: cold air intake
Yeah i was already thinking K&N. i dont need anything super fancy because ill never be able to hide the fact that i have a V6. I could use a little better mileage and its something easy to install that i can spend my money on. Are there specific K&Ns that dont need tuning?
thanks
thanks
RE: cold air intake
ORIGINAL: Yashar
im REALLY new to cars and all so bare with me here im sorry if i suck
i had a friend who told me something about the cold air intakes something like if you drive them in the rain your engine wil lget water in it someting like that
any truth?
any truth?
if you have an almost completely enclosed box around your intake, water can fill up the entire box and create problems
this really does not happy much unless you are going through some BIG puddles though, so we should not be worried at all
