cold air intake
cold air intake
im REALLY new to cars and all so bare with me here im sorry if i suck
i had a friend who told me something about the cold air intakes something like if you drive them in the rain your engine wil lget water in it someting like that
any truth?
any truth?
RE: cold air intake
oh really sweet (never trust an asian!) hah jk hes like my best friend were just lall noobs noone aroudn here knows anything about cars... im tryting to learn doing the best i can im thinking about isntalling one what kind ?for a v6 and how hard would it be to install
RE: cold air intake
Some cold air intakes go down into the fenderwell (none that I've seen in our cars). They could potentially get wet from water being kicked up by the tires or driving in deep water. I think that's more of a problem with imports.
An intake is a pretty easy intall... 15 minutes or so.
RE: cold air intake
The C&L intake is a great product, but it will require that you purchase a handheld computer tuner as well because it pulls in so much air that the air/fuel ratio needs to be adjusted.
There are several companies that offer the cold air intake (CAI) and tuner as a combo for about $550-650 dollars. In my opinion, this is the best mod to make when you're just starting out. The performance gains are very noticeable!
Good luck!
Tim
Good luck!
Tim
RE: cold air intake
thanks for the info on the intake, that was my first thought to get a cold air intake and a tune. I dont know anything about tunes and i hear that C&L intake and SCT X-cal tune make a great combo but im planning on adding other mods aswell after would that require the car to be retuned?
and also how does tuning the car work exactly i know you get some electronic equiptment and it somehow messes iwth the cars computer but thats it?
what about preditor tune?
RE: cold air intake
Part of what makes a tuner such a great first mod is that it can be retuned every time you make another substantial mod. Some examples of things that you'd want to retune for are: larger tires, gear ratio changes, a supercharger/turbo, etc. Many mods won't even require a retune; for example, 99% of exhaust system mods don't require a retune (also called a reflash) because they don't change how much air the engine can take IN (and therefore don't throw off the air/fuel ratio).
A tuner is basically a handheld device (looks like a primitive sort of gameboy) with a big cable that comes out of the bottom and a small LCD screen. You plug the cable into the port on your car (it's near the floor below the steering wheel) and the tuner turns right on. From there you can load a custom tune, check diagnostics, interpret engine trouble codes, and other fun stuff.
A custom tune basically reflashes your car's CPU. You should get tunes written by a qualified shop (I like Doug at Bamachips) or take your car into a place with a dyno (dynamometer) to get a custom tune for your car. A good tuner like Doug can tweak the power bands of your ride to give you better torque and horsepower across the board, especially with a good CAI in your engine compartment!
As for the actual install, the tuner takes 5 seconds to plug in and just a couple minutes to load custom tunes. The cold air intake took me about 45 minutes or an hour but I've heard from others that 15 or 20 is more the average (I am both inexperienced and a perfectionist, so mods always take me a long time!)
Good luck with whatever you decide!
Tim
Tim
RE: cold air intake
Anyone notice a change in shifting (not as much 'kick-down' n auto) after changing to GT takeoff duals..?
maybe I'm focused on the engine sound now that Ihear it more thru the duals, but I feel slower (althought the speedometer tells me otherwise...)
RE: cold air intake
When you buy a hand held tuner does it come with tunes preinstalled? I could do a lot of damage with something like that ...probably make my car spontaniously combust
I would like to get A C&L with a good tune but I am more of a here's what I want you to install for me please dont screw my wallet to bad !!
RE: cold air intake
ORIGINAL: 05 Silvertible
