UPDATE on new 4.0 products *links included*
I have compiled a list of some new aftermarket products for the v6.
Give me your opinions and feedback.
Granatelli Single 70MM Throttle Body 05-06 Mustang V6
Single 70MM blade design fits 2005-06 V-6. Direct OEM replacement, won’t void your factory warranty. Improves mileage and throttle response. Fits stock manifold, stock & aftermarket cold air intakes. 11 HP and 11 ft.lbs. torque. Ideal for modified engines.
6061-T6 billet aluminum construction. Durable anodized finish w/laser engraved logo (natural finish only, blue shown not available). Includes all necessary hardware. Installs in approximately 45 minutes using basic hand tools.
$TBA Available Soon
ASP 2005 + Mustang V6 Underdrive Pulley
The picture says it all. Free up 12hp and 16lbs of torque with the new ASP underdrive pulley for the 05/06 Mustang V6. Requires Gates K060860 belt or equivalent. Belt not included..
$279.99 In Stock NOW
Steeda Sport Shifter Kit - 2005/06 GT and V6 Mustang
With a revised short throw ratio and stop bolts to prevent damage to linkages and shifter under hard usage, this Sport Shifter from Steeda is long on value. Install with our improved urethane bushings (sold separately) for even greater control. Want an even easier installation? Order our Sport Shifter Assembly, and you'll get a new factory shifter rail with our Sport Shifter Kit already attached; just swap out the OEM part, and smoother shifts are yours!
$139.99
most of these can be found at www.v6mustangstuff.com
any additons to this list welcome
$TBA Available Soon
$139.99
RE: UPDATE on new 4.0 products *links included*
The throttle body, yes, absolutely! Especially with a power adder. It could make a huge difference. I'm probably going to get one.
Under drive pulleys don't give you that much hp in the real world, and could cause huge problems. Bad idea IMO.
Shifters help out a great deal, I've heard good things about these. I have an auto so i can't chime in personally!
ORIGINAL: LesteR723
why does everybody want a new throttle body so bad... when it comes to this part of my car intelligence, i'm not very intelligent. Whats the point?
Bigger TB is great when it comes to improving top end but at lower range probably will not make much of a difference. I believe you will loose a bit of low end power but will feel improvement at higher RPM. My 2cents :-) I am still interested in one but want to make sure folks understand that larger TB will not yield improved acceleration from stand still and might even loose some but for racing it will make a world of difference with 11hp gain.
ORIGINAL: thatstang
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
kawiguy827
09-01-2015 07:09 PM
