HAS ANY ONE PUT A CUTOUT ON A STOCK EXHAUST?-now with clips
HEY EVERYONE, OTHER THEN MY AUDIO/VIDEO SYSTEM, MY MAGNAFLOW AXLEBLACK, AND SOME COSMETIC STUFF MY MUSTANG IS PRETTY MUCH STOCK. tHE FIRST OF MY NEW UPGRADES IS GOING TO BE AN EXHAUST CUTOUT ABOUT 2 FEET BEFORE MY MUFFLER, i JUST GOT THE PART THIS WEEKEND FROM JEGS AND I'M BRINGIN IT TO THE SHOP TO GET PUT ON 2MORROW.........DOES ANY ONE KNOW HOW A CUTOUT SOUNDS ON OUR STOCK V6'S???...i HAVE SEEN THE VIDEO BY THAT GUY WHO DID IT WITH DUALS, BUT I WANT TO KNOW WHAT TO EXPECT WITH A SINGLE PIPE
RE: hAS ANY ONE PUT A CUTOUT ON A STOCK EXHAUST?
Can you post some close-up pics of your car? I want to see what the monitor looks like installed. Also where did you mount the x-box? I am thinking about doing the same to mine.
It should sound good, but it will be strange having all that sound coming out of a single exhaust car.
ORIGINAL: pcastle Can you post some close-up pics of your car? I want to see what the monitor looks like installed. Also where did you mount the x-box? I am thinking about doing the same to mine. |
ORIGINAL: Furinox It should sound good, but it will be strange having all that sound coming out of a single exhaust car. |
the only way the sleeper effect is going to work in my opinion is if you get the electric push button valve to open and close it. It wont be much of a sleeper if they hear you coming.
I'm curious why anyone would want to run an exhaust cutout? If you shunt the exhaust out before the muffler, you're going to lean out your A/F mix and the car will actually run slower more than likely. Are you wanting it to be loud just for fun?
The screen looks very cool in the tiny sig pic! |
mine doesn't run slower.
as long as you dont remove the O2 sensors it shouldnt lean out. Maybe loose a little low end, but (especially with single muffler) it should help in the higher rpms. That head unit looks sweat! Thought about buyin a system but decided to spend the money on performance.
Ur exhaust shouldnt have anything to do with your air to fuel ratio because its going out of the engine not in...U do loose a little back pressure but as someone just mentioned on a single pipe car with a decent sized motor it makes no difference......
I actually just put the cutout in and it sounds great!!! I feel like I may have lost a tiny bit of my low end torque...but boy does the power in 3500 to 4500 rpms make up for it!!!!.... It has a much deeper throaty sound now too!....no offense to those that spent hundreds on custom catback and duel set ups.....but i feel like i got the same effect for less than a quarter of the price....plus i've lost less back pressure because its still a single pipe.....the install is very clean and one would think that all the exhaust is coming out of my axleback!!!.. going back to my normal set up is very quick and easy.....would reccomend to anyone....but makes sure u get the jegs cut out!!!! Thanks for the compliments on my screen.....its actually just a monitor...i relocated my aftermarket head unit to my glove compartment.its a much better option then spending over a thousand on an indash dvd/screen combo...that u cant even use while in motion...i'm goin to post before and after clips of my exhaust this evening |
