Procharger set up
#42
RE: Procharger set up
ORIGINAL: scrming
Couple of things...
Pick up a issue of this month 5.0 magazine... There is a nice write up by PHP on installing the Vortech in an V6. I actually seen this car in person... very nice indeed! The gentleman said they car is consistently running 13.5 on STREET tires! Not to shabby!
If you shop can install a procharger, they sure as heck better be able to install a Vortech! LOL! And you don't tap into the oil pan... you actually tap a whole in the timing cover.
Here is the actual install manual from Vortech: http://www.vortechsuperchargers.com/...u218_v6_im.pdf
While you're there... Vortech has some interesting articles... of course they are from Vortech so perhaps you need a grain of salt... but they are interesting none the less...
Head to head: http://www.vortechsuperchargers.com/...1sc_report.pdf
Air-Air vs Air-Water: http://www.vortechsuperchargers.com/...oler_paper.pdf
Couple of things...
#43
ORIGINAL: Jimp
Is that the feed or return line? The instructions I saw for a Vortech had you tapping one of the holes(no w, lol) in the engine block! Unless they have changed it. This was instructions that Forced(guy from Vortech) posted. FYI.
ORIGINAL: scrming
Couple of things...
Couple of things...
For the oil supply line you simply put a Tee in where the oil pressure sending unit is:
The oil drain is the one that requires a new hole. It's goes in the timing cover: (The 5.0 article has a better pic)
#44
ORIGINAL: scrming
From the Vortech install guide...
ati, charger, cooling, guide, install, installation, instructions, lawsuit, manual, mustang, pdf, procharger, prochargerlowend, set, vortex
