saleen front sway bar
Well, I installed the GT front sway bar which is 34mm in diameter compared to our stock 28.6mm. That in addition to my rear sway bar from Hellwing which I installed 2 weeks ago. Took the car around some sharp turns and all I have to say is WOW. I don't feel any leaning at all now. The only problem that I did notice are the crapy stock tires do not want to hold on to the road and start to skidd easily if I am not carefull. I was thinking of getting wider tires for the rear to compensate and leaving the front ones alone.
I strongly recommend getting a bigger sway bar in the front after adding rear one.
My input.
My input.
RE: saleen front sway bar
Glad to hear it, I plan on doing the same. As for leaving the front tires alone, I think if you do that you'll find you'll have some major understeer problems, especially with stickier tires on the back.
When you say stock tires are you talking about the 16's or the stock Pirelli's from the GT? I also have the Hellwing and am considering the GT front from Saleen but I have the Pirelli's. I hope they stick, I don't want to buy new tires until I wear these out!
ORIGINAL: thatstang
My input.
My input.
I do my own work :-) Changin sway bars is a very easy task. To change the front one you need an 18mm wrench, 8mm wrench and a 15mm deep socket. Takes 20-30 min if you get enough clearence in the front. I jackedthe front and lowered it back to ground before final torque.
My tires are stock 16" and I don't want to switch to GT rims because of extra 32lb unsprung weight :-) If I get a 235/60 tires in the rear thats only 6lb of extra unsprung weight and should be ok.
I am one of those, who beleives that light is better and ended up adding 25lb of sway bars :-) but handles so goooooddddd.
mungodrums
09-28-2015 10:54 PM
