SSE Gen II Center Exhaust
RE: SSE Gen II Center Exhaust
not sure.... the saleen one has small downpipes mid way to help reduce backpressure as the 1 oppening at the end of the pipe isnt quite big enought... so for the v6 u may have to block the mid way exits or u will loose a bunch of low end power.
Paul
Paul
I have the saleen mufflers on my car. Unless you plan on getting the saleen rear body kit its not going to work. The Saleen rear facia extends about 6 in. further than the stock bumper to make room for the pipes to come out the center.
the down pipes are not mid way, they are on the end of the muffler themselves..
for the bumper, id go to your local muffler shop and have them macguiver something
ill tell you a secrete tho, you loose power with center exhaust unless you have the pipes comming straight up the middle, because for every 90deg bed you lose 25% flow, then with the next bend you lose 25% flow from the sum of your first lost
with the saleen with the dump pipes would make it go striaght pipe (through the muffler) no backpressure (the engines displacement is large enough to make power with backpressure (so is our V6's) we arent driving hondas) with teh pipes striaght through no loss in flow!
