Lowering Springs
Old 06-04-2006, 09:15 PM
chipschwab
chipschwab's Avatar
Default Lowering Springs
I plan on lowering my car soon and i want to get eibach pro-kits. I was wondering if i can do the install myself? And if there are and write ups on how to do so. Thanks.
chipschwab is offline
Old 06-04-2006, 10:23 PM
xXxMUSTANGxXx
xXxMUSTANGxXx's Avatar
Default RE: Lowering Springs
no idea bro but that is good choice eibach pro-kit
xXxMUSTANGxXx is offline
Old 06-04-2006, 10:32 PM
afixer
afixer's Avatar
i have the steeda kit the rear are easy but the front will require a spring compressor and 14mm camber bolt kit ( any napa parts shop will have them) and a alignment. should take about 3 hours plus the alignment
afixer is offline
Old 06-04-2006, 10:41 PM
blackfoot
blackfoot's Avatar
yeah yu can do it yourself, when doing the front springs jack the front up (both sides), then when doing the rear jack up the rear both sides.. ifyou just do one corner at a time the sway bar will stop you from removng the sway bar link, and lets jsut say your be very frustrated
the rear is easy to do,
jack up rear end (put jacks under rocker pannel on jack notches)
jack up your axle from the diff, make sure your not jacking from the diff cover
unbolt lower shock bolt, on each shock,
lower jack
grab spring and wiggle loose
remove and replace
make sure the spring sits in the grove right youll see where the spring is supost to sit
reverse steps
for the front
jack car up from rockers put jack stands on the notchs
unbolt wheel
unbolt sway bar link (prefferably the one connected to the strut)
unbolt both lower strut bolts
place small jack stand under the rotor to support it up
unbolt the 4 small nuts under the hood holding your strut up
remove strut
(i purchased a spring compressor from my local snapon guy, costed me 80$)
use spring compressor on spring and remove strut top nut
(note go to your local ford dealer and pick up 2 new top nuts (they arent re-usable and even if they are re-used and are torqued down they will back off on thier own)
decompress spring
put new spring (make sure it sits right in its groove)\
compress spring
put top plate on, make sure the arrow faces to the lower strut bolt mounting bracket
torque down top nut
decompresse spring, and reverse the above steps to get it back in
blackfoot is offline
Old 06-04-2006, 10:46 PM
blackfoot
blackfoot's Avatar
also the camber bolts go in the upper of the 2 lower strut bolts, you can align it yourself witha level vertically, its not as accurate as a machine but it works, but you have to be patient lol, cuz youll be jacking your car up and down a few times to adjust
Old 06-06-2006, 12:26 AM
chipschwab
chipschwab's Avatar
Hmmm....How much would an installation... lets say from ford cost me?
Old 06-06-2006, 12:38 AM
blackfoot
blackfoot's Avatar
i would bring it to a performance shop to get it done.. a local shop around here quoted me 80$ canadian but i guarrentee a dealer would milk you for this kind of installation
Old 06-06-2006, 12:39 AM
paulboy16
paulboy16's Avatar
is there just a rear lowering kit??? or would u HAVE to do the front too??
Paul
paulboy16 is offline
Old 06-06-2006, 01:41 AM
Black06stang
Black06stang's Avatar
Roush sells just the rear lowering springs.
Black06stang is offline
Old 06-06-2006, 01:51 AM
lrgnation
lrgnation's Avatar
http://forums.bradbarnett.net/showthread.php?t=47261
lrgnation is offline
Quick Reply: Lowering Springs
