Cams
RE: Cams
i really want to go all motor on my car, but it just seems like nobody wants to try out the supersix cams. somebody needs to tell them to dyno them. If they made a decent amount of power i would definately get them. I think with all the bolt ons, cams, and maybe some head work we could be making some high 200's.
RE: Cams
ORIGINAL: LX200
OK, I'm dense... what is a cam gong to do for us? Lift the valves higher? Longer? What effect does that have? How about a little cam theory here...
Cams control the timing if your valves. If your valves are opern for longer, more air can flow. It's the same basic idea as forced induction just not as drastic.
More air = more power. SOMEONE TRY THE SUPERSIX ONES PLEASE!!!
RE: Cams
Everyone seems to be going FI, if i had the money i would probably go all motor too. Probably next summer i will start building up a separate engine. I really want to stroke it to 4.4L too. Maybe it wouldnt make quite as much power as FI but it would certainly be a unique set up. Plus you wouldnt have to worry about the extra maintenance either. Add all that to a high stall converter and im sure you'd give a FI 4.0 a run for its money!
RE: Cams
ORIGINAL: LX200
That said, from what I understand, it seems that cams regulate valve timing. Thus, different cams could make the same engine behave differently, from being more aggressive to making it detuned and sluggish.
Here's an article on the mighty wikipedia, all hail.
http://en.wikipedia.org/wiki/Camshaft
Any tech-or mechanically inclined people who would like to correct me, please do so. I'm always ready to learn.
RE: Cams
Changing cams on OHC engine is not that hard. I changed the one on my Civic in 1 hour plus 20 min to set valve clearence. Ours take a bit longer but should be streight forward plus I don't think we need valve adjustment with hydraulic valves.
RE: Cams
ORIGINAL: thatstang
RE: Cams
ORIGINAL: thatstang
uhhhh, I see. I dont have a shop guide but assumed its like others. Thanks. I'll try to search online for cam swap on 4.0L engine.
RE: Cams
Id probably have the guy who installed my gears put them in. His shop is pretty much ford. Labor is cheap too, he charged 200 bucks to put in my gears. Although i wont be doing much else until im on my own insurance. And if you want to build a v6 to run 11's or maybe high 10's, you cant do it just by cranking up the boost or forcing in more nitrous, you need a good foundation as well. Just imagine what a 4.0 with a more aggressive cam and ported heads along with some FI could do. I know its easier and cheaper to slap on a SC or TC, but what do you do after that? I think ill build my car from the ground up (almost literally).
