Rygen is at the track!
RE: Rygen is at the track!
He said he thinks the PNeros hooked better than the Nittos, which are much wider! He tried launching at idle on his last run and got a 13.4@105. Still a 2.2 60' time so he's definitely got traction problems. He's going to run DRs next time out he said so he should hit 12s no problem.
ORIGINAL: Jeremy
That would be awsome to see one of our cars run in the 12s! Is he spraying also?
Jimp, thanks for posting this man, appreciate it. Ok, got home, I'm done for the day. Need to fire up the grill and open a cold one.
Best run of the day, out of 4 runs is:
[ul][*]R/T: .269[*]60: 2.2[*]330: 5.81[*]1/8: 8.73[*]MPH: 83.65[*]1000: 11.27[*]1/4: 13.41[*]MPH: 105 (holy crap!!!!)
[/ul]
She's got 12's in her, I know it cause of my trap speed. Today was a blast, but tough! I could not hook!!!! I was all over the place on the Nittos, even did pro burn outs on them.
I know once I get my DR's, its on!!!!! The other thing, and ranebow and I have been talking about this (and he is making the same recomendations as PH) is I may want to consider the stock gear. The 3.73's may be a tad tall for all the power I'm running.
So there you have it, thanks for the support. And thanks Jimp/BlackLX, Scrming, Afixer and Ranebowcyxx for the talks from the pit and the suggestions.
[/ul]
Here is some more info, it was pretty hot today, I'm sure we hit 96 or 97. Here is the conditions at the track today, and the turbo still did well:
[ul][*] Temperature: 94-97f[*] Humidity: 38%[*] Pressure: 30.03 in.[*] Dew Point: 63°F
[/ul]
[/ul]
