Boost Vac Gauge .... little help
I am getting close to installing my gauges...... I need to know if a Boost/Vac gauge can be used to monitor Vac only.
My S/C project has been postponed until next year, but I want to still use the Boost/Vac Gauge... Obviously It will not monitor Boost
But the question I have is....... can it be hooked up to a vac line to monitor for low vac / leaks..?
Thanks!!
Thanks!!
RE: Boost Vac Gauge .... little help
dont see why not i have a vac boost gauge and it works for the vac just fine. that sounds like a good idea if you are going sc later. you may get the ocational hey wher is the sc. if someone notices. but all you have to say is its coming. ya gota start somewhere!
Thanks Afixer.....
I certantly do not want to "pretend" to have Boost, but on the other hand I do not want to have to rip the Pod from the dash (3M to the dask) to install the Gauge later.
+ if I can monitor Vac at least it will be semi-functional...
Thanks
Thanks
jwog666
12-27-2021 08:09 PM
Galactic
04-29-2019 02:56 PM
andrew1969
16
01-08-2016 02:48 PM
